Windows 11
Just installed Windows 11. The Go-Flight MCP light's up but none of the knobs or switches work. :(
  • I might of jumped the gun, so to speak. After a reboot it is working on the Black Box islander. As yet though I haven't tested more aircraft. I post again if I find any that will not work with the MCP.
  • edited October 2021
    Again in Windows 11 when the A320 default is loaded all the tabs on the panel remain greyed out and not pressable.
  • Hmm! Rolled back to Windows 10. Re-installed GIT and the extra plug in in the community folder, the MCP lights up but none of the knobs work :(
  • Re downloaded GIT and a new install, the MCP lights up but none of the switches or knobs work, might as well use it as a door stop
  • Anyone please?
  • All OK, I fixed it.
  • Please tell us how you fixed it.
  • echo, please what did you do to fix it?
  • First I uninstalled GIT, then went into the regedit and did a search for "goflight" I probably found about three or four entries which I deleted from the editor. Then after finding no more entries for goflight listed I reinstalled a new fresh download of GIT, but do remember to install as Administer.
  • Thanks for the info
