MSFS 2020 Lua Connection Failures
Hi There,
Since the SU5 update whenever I load the GIT I am getting Winsock Lua errors and cannot test/run Lua events etc. The error I am getting as soon as GIT loads is:
LUA Processor: Connect Exception - Unable To Connect!
WinSock: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:27016
Any idea how I can resolve this?
Neil
Neil
When starting up LUA does connect via the port as I get the message
WinSock: Connected To 127.0.0.1 On Port 27016!
LUA Processor: Started!
It then detects loads of LVARs for the FBW A320 and then soon after I start to get the Connect errors previously listed.
Neil
Debugging Started
Joystick Data:
Joystick Device Found: T.A320 Pilot
Joystick Device Found: Saitek Pro Flight Yoke (USB)
Joystick Device Found: Saitek Pro Flight Rudder Pedals
Joystick Device Found: Generic USB Joystick
FP Device Found: TCA Q-Eng 1&2
Device Found: GoFlight GF-T8 control module
Device Found: WCP
Device Found: MFR
Device Found: GF-46
Device Found: MESM
Device Found: ITE Device(8595)
Device Found: Saitek Pro Flight Switch Panel
Device Found: MFR
Device Found: WCP
Device Found: GF EFIS
Device Found: USB Receiver
Device Found: MCP Pro
Device Found: MFR
Device Found: RP-48
Supp Device Found: Button Box Interface
Supp Device Found: BU0836X Interface
Mouse Device Found: Mouse
Keyboard Device Found: Keyboard
Qty: 7
Joystick Found Device 0: T.A320 Pilot
Device 0 Button Count: 17
Device 0 POV Count:1
T.A320 Pilot
Y
X
Sliders0
RotationZ
Joystick Found Device 1: Saitek Pro Flight Yoke (USB)
Device 1 Button Count: 23
Device 1 POV Count:1
Y
X
RotationY
RotationX
Z
Joystick Found Device 2: Saitek Pro Flight Rudder Pedals
Device 2 Button Count: 0
Device 2 POV Count:0
Y
X
Z
Joystick Found Device 3: Generic USB Joystick
Device 3 Button Count: 12
Device 3 POV Count:1
RotationZ
Z
Z
Y
X
Joystick Found Device 4: Generic USB Joystick
Device 4 Button Count: 12
Device 4 POV Count:1
RotationZ
Z
Z
Y
X
Joystick Found Device 5: TCA Q-Eng 1&2
Device 5 Button Count: 31
Device 5 POV Count:0
TCA Q-Eng 1&2
Z
Y
X
RotationZ
Sliders0
RotationX
RotationY
Joystick Found Device 6: Button Box Interface
Device 6 Button Count: 128
Device 6 POV Count:1
SimConnect Message Processing Started
SimConnect Receive Message Exception: startIndex cannot be larger than length of string.
Parameter name: startIndex
LvarName Request: A32NX_RMP_L_TOGGLE_SWITCH
LvarName Request: A32NX_RMP_R_TOGGLE_SWITCH
LvarName Request: A32NX_RMP_L_SELECTED_MODE
LvarName Request: A32NX_RMP_R_SELECTED_MODE
LvarName Request: A32NX_RMP_L_VHF2_STANDBY_FREQUENCY
LvarName Request: A32NX_RMP_L_VHF3_STANDBY_FREQUENCY
LvarName Request: A32NX_RMP_R_VHF1_STANDBY_FREQUENCY
LvarName Request: A32NX_RMP_R_VHF3_STANDBY_FREQUENCY
LvarName Request: XMLVAR_ENG_MODE_SEL
LvarName Request: LANDING_1_Retracted
LvarName Request: LANDING_2_Retracted
LvarName Request: XMLVAR_Baro1_Mode
LvarName Request: XMLVAR_SWITCH_OVHD_INTLT_SEATBELT_Position
LvarName Request: XMLVAR_A320_WeatherRadar_Sys
LvarName Request: A32NX_AVIONICS_STARTUP_SOUNDS_INHIBIT
LvarName Request: A32NX_OVHD_ADIRS_IR_1_MODE_SELECTOR_KNOB
LvarName Request: A32NX_OVHD_ADIRS_IR_2_MODE_SELECTOR_KNOB
LvarName Request: A32NX_OVHD_ADIRS_IR_3_MODE_SELECTOR_KNOB
LvarName Request: A32NX_OVHD_ADIRS_IR_1_PB_IS_ON
LvarName Request: A32NX_OVHD_ADIRS_IR_2_PB_IS_ON
LvarName Request: A32NX_OVHD_ADIRS_IR_3_PB_IS_ON
LvarName Request: A32NX_OVHD_ADIRS_ADR_1_PB_IS_ON
LvarName Request: A32NX_OVHD_ADIRS_ADR_2_PB_IS_ON
LvarName Request: A32NX_OVHD_ADIRS_ADR_3_PB_IS_ON
LvarName Request: XMLVAR_SWITCH_OVHD_INTLT_NOSMOKING_Position
LvarName Request: XMLVAR_SWITCH_OVHD_INTLT_EMEREXIT_Position
LvarName Request: A32NX_OVHD_INTLT_ANN
LvarName Request: XMLVAR_Auto
LvarName Request: XMLVAR_ALT_MODE_REQUESTED
LvarName Request: XMLVAR_A320_WEATHERRADAR_MODE
LvarName Request: A320_Neo_AIRCOND_LVL_1
LvarName Request: A320_Neo_AIRCOND_LVL_2
LvarName Request: A320_Neo_AIRCOND_LVL_3
LvarName Request: PUSH_OVHD_OXYGEN_CREW
LvarName Request: STROBE_1_Auto
LvarName Request: A32NX_BARO_BRIGHTNESS
LvarName Request: A32NX_SWITCH_RADAR_PWS_Position
LvarName Request: A32NX_COLD_AND_DARK_SPAWN
LvarName Request: A32NX_ELEC_COMMERCIAL_FAULT
LvarName Request: A32NX_ELEC_COMMERCIAL_TOGGLE
LvarName Request: A32NX_ELEC_GALYCAB_FAULT
LvarName Request: A32NX_ELEC_IDG1_FAULT
Hereafter loads of similar A32NX LVAR request / detected messages followed by:
LvarName Update: A32NX_AUTOBRAKES_BRAKING
Late Lvar Detected: A32NX_AUTOBRAKES_BRAKING
LvarName Update: A32NX_AUTOPILOT_TRACK_SELECTED:1
Late Lvar Detected: A32NX_AUTOPILOT_TRACK_SELECTED:1
LvarName Update: GPS_Current_Phase
Late Lvar Detected: GPS_Current_Phase
LvarName Update: PFD_BRG1_Source
Late Lvar Detected: PFD_BRG1_Source
LvarName Update: PFD_BRG2_Source
Late Lvar Detected: PFD_BRG2_Source
LvarName Update: Glasscockpit_DmeSource
Late Lvar Detected: Glasscockpit_DmeSource
LvarName Update: DOOR_MAIN_DOOR_POS
Late Lvar Detected: DOOR_MAIN_DOOR_POS
LvarName Update: Main_Door
Late Lvar Detected: Main_Door
LvarName Update: A32NX_GOAROUND_PASSED
Late Lvar Detected: A32NX_GOAROUND_PASSED
LvarName Update: AIRLINER_APPR_TRANS_ALT
Late Lvar Detected: AIRLINER_APPR_TRANS_ALT
LvarName Update: XMLVAR_STBYBattery_Test
Late Lvar Detected: XMLVAR_STBYBattery_Test
LvarName Update: XMLVAR_BatterySTBY_SwitchState
Late Lvar Detected: XMLVAR_BatterySTBY_SwitchState
LvarName Update: XMLVAR_STBYBattery_IsHeld
Late Lvar Detected: XMLVAR_STBYBattery_IsHeld
LvarName Update: XMLVAR_ELECTRICAL_Switch_Power12V_ON
Late Lvar Detected: XMLVAR_ELECTRICAL_Switch_Power12V_ON
LvarName Update: XMLVAR_LeverMixtureHidden1
Late Lvar Detected: XMLVAR_LeverMixtureHidden1
LvarName Update: PFD_CDI_Source
Late Lvar Detected: PFD_CDI_Source
Creating Bespoke Vars
Bespoke Vars Created
Importing Bespoke Variables
Bespoke Vars Assigned, Importing Bespoke Events
Bespoke Events Temp Imported
Bespoke Events Imported
Loading Aircraft Settings
GetXMLConfigData
GotXMLConfigData
Loading Power
Loading MCPPRO
Loading MCP
Loading EFIS
Loading P8
Loading T8
Loading RP48
Loading MESM
Loading WP6
Loading LGT
Loading LGT II
Loading GF46
Loading GF45
Loading TQ6
Loading DIO
Loading GF166
Loading SECM
Loading Joysticks
Clearing Displays
Reset Data
Aircraft Settings Loaded
Calling Aircraft Changed
Aircraft Changed
These errors continue ad infinitum until I closed down.
Unfortunately nothing of interest in the IOLua log, all there is is this:
10-35-23: FlightSimIOLua Starting ...
10-35-23: LuaProcessor Starting ...
10-35-23: LuaProcessor Started.
10-35-23: TCPServer Starting ...
10-35-23: TCPServer Connecting To 127.0.0.1 On Port 27016 ...
10-35-23: TCPServer Started.
10-35-23: FlightSimIOLua Started: 1
10-35-23: TCPServer Listener Starting ...
10-35-23: TCPServer Listener Started!
10-35-27: TCPServer Client Listener Starting.
10-35-27: TCPServer Client Listener Started.
Neil
Hope this helps.
Neil
Any progress or suggestions on this please. I am now running the latest GIT with the stable 0.7.0 FBW 320 and I still get exactly the same easily recreateable problem.
Neil
Log Name: Application
Source: Application Error
Date: 05/10/2021 14:55:54
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: DESKTOP-3ISDGK3
Description:
Faulting application name: FlightSimIOLua.exe, version: 1.0.0.1, time stamp: 0x6130dcab
Faulting module name: FlightSimIOLua.exe, version: 1.0.0.1, time stamp: 0x6130dcab
Exception code: 0xc0000005
Fault offset: 0x0000000000041d53
Faulting process ID: 0x437c
Faulting application start time: 0x01d7b9f025802145
Faulting application path: C:\Program Files\GoFlight\FlightSimIOLua.exe
Faulting module path: C:\Program Files\GoFlight\FlightSimIOLua.exe
Report ID: c5302e1e-e8a4-40f0-8efe-a704cdac7191
Faulting package full name:
Event Xml:
1000
0
2
100
0
0x80000000000000
27247
Application
DESKTOP-3ISDGK3
FlightSimIOLua.exe
1.0.0.1
6130dcab
FlightSimIOLua.exe
1.0.0.1
6130dcab
c0000005
0000000000041d53
437c
01d7b9f025802145
I've tried reinstalling GIT but to no avail.
Neil
PS: Unistalling GIT for MSFS2020 also uninstalls GIT for P3D
Neil
setlvar("AS1000_Warnings_Master_Set", 1)
and it worked fine. Can you try the above and see if it errors for you. I tried from the Lua console and assigning to a switch and there was no crash.
That does seem to work on most planes without crashing so I have done a bit more investigating and I think I have narrowed it down to using Bespoke Vars.
If I use setlvar("A320_Neo_MFD_NAV_MODE_1",1) then it seems to work OK on the FBW A320..
However if I use setlvar("A320_Neo_MFD_NAV_MODE_1",BespokeVar3) then it crashes.
Hope this helps.
Neil
Lua will see BespokeVar3 as an internal local variable when used in the way you are using it. However, it shouldn't be crashing Lua, so I will still investigate.
