ABORT event shuts down P3D ... how to set to No_Event
Working thru my PMDG 737 mapping. In my quest to remove an event associated with On (On/Off/Hold), I couldn't find an NULL or "No Event" so I set it to ABORT thinking this was a null event ... boy was I mistaken, it shuts down P3D with no warning/confirmation.
I realize I can edit my XAML to remove the association, but was trying to stay within GIT. Is it safe to set to "BLANK"?
Cheers, Rob.
Hi Rob,
BLANK is the correct event to remove the association.
Hi Rob,
I have seen that issue before quite a lot. If memory serves me correctly you need to disable the power management for all the Goflight devices (and possibley the hubs) so they don't get turned off when not being used.
Windows USB was rightly called Plug and Pray!
Glad its sorted.
