Newest GoFlight Interface Tool Update GIT P3Dv4v5 64Bit is faulty !!!
I just installed the latest update over my existing version 3.8.2.
Version 4.5.1.1 is giving me lots of errors. I can only dial the numbers to the right (higher values). Left dial doesnt work. Some of the switches are only flippable upwards but not downwards. I use the MCP and EFIS. They are recognized correctly and the Status is 3 green lights.
Is there any chance to get the old version 3.8.2 back since it was working ok.
Thank you!
Best regards Andi
  • I forgot to mention that I'm running the latest version of the NGXu under P3Dv5.2.
    Is there a section for older versions where I can download the old 3.8.2?
  • Bug is fixed, you can download a new version now. 64Bit only. Will update the other versions over the next hour or so.
  • Hi Steve, its working great now. Thanks!
