Hvar Problem with MSFS200 & FBW A320
I'm having problems running Hvar events for the FBW A320 in MSFS 2020. Whenever I try to run the SENDCEVT command I get the following error
Error: ...GOFLIGHT INTERFACE TOOL\LUA\FLYBYWIRE_A320_NEO\TEST2.LUA:1: attempt to call a nil value (global 'sendcevt')
I am trying to run sendcevt("H:A320_Neo_PFD_BTN_LS_1") but I get the same error whatever Hvar I try to use, even using the example you use in the guide.
Any idea what I am doing wrong, do I need to somehow read in the Hvars somewhere first? I have no problem running this Hvar from either FSUIPC or Lorby's AxisandOhs.
Neil
Neil
Neil
FYI - Ver 4.5.1.2 fixes the bugs I encountered in the initial update V4.5.1.1 two days ago.
All my modules are working correctly. (Ver P3DV4.5)
Claude
