GIT FS2020 simConnect status Yellow
Hello,
I was off the sim for a while and now back to it.
Using GIT V4.5.1.1
I don't know if it is a function of the SU7 but simConnect shows the yellow color!
I always launch GIT while my flight session is loading, just after the session finished loading SimConnect goes green for 1 sec and goes back to yellow right away and stays that way.
Am I missing something?
Thanks for any help.
  • Here is the log:
    12:23:38 GoFlight Connection Starting.....
    12:23:38 SimConnect Connection Starting.....
    12:23:39 SimConnect Message Processing Started
    12:23:39 GoFlight Connection Started
    12:23:39 SimConnect Connection Started
    12:23:39 Aircraft Connection Starting.....
    12:23:39 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    12:23:39 SimConnect: Event Received: SIM, 1
    12:23:39 SimConnect: Event Received: PAUSE, 0
    12:23:40 WinSock: Connected To 127.0.0.1 On Port 27016!
    12:23:40 LUA Processor: Started!
    12:23:40 Aircraft Connection Started
    12:23:40 SimConnect: Exception Received: OUT_OF_BOUNDS
    12:23:40 Simconnect Version: 11.0.62651.3
    12:23:40 Aircraft FullName: Aerosoft_CRJ_700
    12:23:43 SimConnect: Exception Received: OUT_OF_BOUNDS
    12:23:46 SimConnect: Exception Received: OUT_OF_BOUNDS
    12:23:49 SimConnect: Exception Received: OUT_OF_BOUNDS
    12:23:52 SimConnect: Exception Received: OUT_OF_BOUNDS
  • I never had to include the WASM module in the community folder before. I tried and nothing changes still OUT OF BOUNDS!
    Please help, in desperate need of my goFlight peripherals : )
  • That error is due to the WASM module missing.
    The WASM Module is needed in the Community folder. It needs to copied into it as the directory and not the individual files.
    There are plenty of vids on the internet about locating your Community folder.
  • At the moment I see two community folders, and I am using the STEAM edition of MSFS2020
    One is in:
    C:\Users\XXXXXX\AppData\Roaming\Microsoft Flight Simulator\Packages\Community
    I see the pollypotsoftware-flightsimio-module folder being in that Community folder.
    I also see another pollypotsoftware-flightsimio-module with a different content inside it ( .cache .dll .lib .natvis pdb files) located in:
    The other:
    D:\FLIGHT SIM\MSFS2020\Packages\Community
    This one does not have the pollypotsoftware-flightsimio-module folder in it?
    I am pretty confused at the moment, can you explain in which Community folder and/or packages folder the pollypotsoftware-flightsimio-module folder containing the .wasm should be put in. In the Community folder located in the AppData or in the one located D:\FLIGHT SIM\MSFS2020\Packages\Community?
    Thanks for your helping clarify this multiple folder issue. I would like to remove any pollypotsoftware-flightsimio-module I don't need.
  • Finally I got it to work, I think for some reason there was some left over from maybe old installation, but by removing both pollypotsoftware-flightsimio-module folders from:
    and
    I certainly did not put them there myself!
    and having it ONLY in:
    F:\FLIGHT SIM\MSFS2020\Packages\Community
    Now works again like a charm : )
    Hope this helps other people as well!
  • I have the very same problem after the migration of FS2020 to another hardware drive (simconnect shows up green for a second, then turns to and stays yellow).
    I do understand, that this WASM module has to to be put into the community folder. But a simple question remains: Where can I find and download this module? Sounds like it may be found here inside Pollypot, but I definetely did NOT find it here.
    Cheers
    Claus
    Cheers
    Claus
    It goes yellow if an exception occurred. You have to check the log to see if the error continually repeats, then you have a problem, otherwise the yellow light can be ignored.
    You can download the WASM module from your account where you downloaded GIT in the first place.
