Installation Error
I am trying to install my MCP Pro and EFIS on a new PC With new installation of windows 10 and FSX (from DVD). I have installed GF Config Setup 2_28_0 and GoFlight Interface Tool 3_6_5_1following the installation guide on this site. When I first start up FSX with the default flight, the MCP windows show dashes. When I load a saved flight cold and dark I get the following error message: Unable to load bespoke events. The cloud file provider is not running. TAKE A COPY OF YOUR SETTINGS BEFORE DOING ANYTHING ELSE. The MCP in this situation shows nothing on the displays and does not do anything.
Can anyone help please
1. FD switch inoperative
2. A/T switch inoperative
3. IAS rotary works
4. Heading selector works
5. Altitude Selector inoperative, but mirrors what I select on screen
6. Vert Speed inoperative, but mirrors what I select on screen
7. A/P switches inoperative, but mirror what I select on screen.
8. I have the latest software and .xml files look ok
Do you have any more ideas please?
Many thanks
Remember you need to do the above whenever you first fly a particular aircraft, after that, GIT remembers the settings.
PS: If you are using complex 3rd party aircraft, they may not be fully Simconnect compliant. That is what Detective is for, to help you spot event and lvars that can be used to correctly configure the MCP Pro.
USB 3 works for most people, but GoFlight recommend USB 2.
