Goflight MPC Anvanced Autopilot
Since the MSFS SU7 my Goflight MPC Advanced Autopilot no longer works. All LEDs are dark. Everything else (GF166, GF LGT, GF T8) is OK. The hardware is OK I tested it.
thanks for your help
Peter
  • Have you checked each of the LED's are configured and the device is enabled? Is the brightness level correct on the MCP tab? Is USB power management off? Have you tried a different USB port?
  • Hello Steve i followed your tips but to no avail. When the PC starts up, the LEDs light up briefly. the error only occurs in msfs. before su7 everything worked. greet Peter
  • Do the rotaries and buttons work (i.e. when used, change something in the sim)?
  • Hello Steve yes the controls all work. Greetings Peter
  • edited December 2021
    OK, download and install the GoFlight drivers and read the readme file that gets installed where it talks about Windows8Fixer (it applies to Windows 10 as well). Do what it says and see if that sorts the displays and LED's out.
  • Hello Steve
    Thanks for the advice. everything is ok now. kind regards Peter
