BUG REPORT : GF-45 and LIGHTACTIONS on the GoFlight Interface Tool for X-Plane
When using the LIGHTACTION="ROUND" with the GF-45 no values are displayed only the LIGHTLABEL="SPD".
When you then change in the interface the LIGHTACTION="NOTHING" the value is displayed, if you then change it back yo ROUND it works until restarting the interface or X-PLANE. This issue seems also present when using other LIGHTACTIONS on the GF-45.
ex.
When doing the same on the GF-46 I do not have that issue. So seems a BUG in the interface with the GF-45's.
ex.
This is what I have in the xml
The strange thing is when it isn't displaying in flight, I change in the interface the setting to nothing and then back to round, the value is is diplayed.
I now added a 3rd control ID, which displays sim/cockpit/autopilot/airspeed which is a value without numbers after the comma, and when I toggle then back to the airspeed_kts_pilot, it shows the rounded value (no digits after the comma).
Same if I do the same on my GF-46 with the same Custom Value it works diretly.
So it's definitly something in combination with the GF-45's.
