need help - Winsock connection failed, LUA processor unable to connect
Hi
I have a problem to connect goflight mcp with goflight interface moudle.
Currently, I am using P3D V5 latest version, PMDE 737 NGXU ( I have trouble with FS2020, but I need to solve this one first..)
I have installed GFconfig ( downloaded from goflight latest software page )
installed goflight interface tool p3DV4V5 64bit
after running goflight interface tool, I can see the green light on GOflight, simconnect and aircraft at status screeen
but ( green light is blinking on only below aircraft )
running CFconfig first, just light on at led button. nothing on display
after running interface tool, it is same. there is light on button but nothing on display at course... ias/mach and others.. no light on screen.
so I have checked log as below and there seems error at winsock and lua connection.
04:54:30 GoFlight Connection Starting.....
04:54:30 SimConnect Connection Starting.....
04:54:30 SimConnect Message Processing Started
04:54:30 GoFlight Connection Started
04:54:30 SimConnect Connection Started
04:54:30 PMDG SDK option is OK in Prepar3D v5
04:54:30 Aircraft Connection Starting.....
04:54:30 SimConnect: Event Received: Aircraft Type Changed
04:54:30 SimConnect: Event Received: SIM, 0
04:54:30 SimConnect: Event Received: PAUSE, 1
04:54:30 SimConnect Message Processing Finished
04:54:31 SimConnect Connection Starting.....
04:54:31 Creating Bespoke Vars
04:54:31 Bespoke Vars Created
04:54:31 Importing Bespoke Variables
04:54:31 Bespoke Vars Assigned, Importing Bespoke Events
04:54:31 Bespoke Events Temp Imported
04:54:31 Bespoke Events Imported
04:54:32 SimConnect Message Processing Started
04:54:32 GoFlight Connection Started
04:54:32 SimConnect Connection Started
04:54:32 Aircraft Connection Starting.....
04:54:32 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
04:54:32 SimConnect: Event Received: SIM, 0
04:54:32 SimConnect: Event Received: PAUSE, 1
04:55:03 WinSock: Connection Failed: 전송 연결 연결된 구성원으로부터 응답이 없어 연결하지 못했거나, 호스트로부터 응답이 없어 연결이 끊어졌습니다에서 데이터를 읽을 수 없습니다.
( I think this is "Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond." in English. )
04:55:03 LUA Processor: Connect Exception - Unable To Connect!
04:55:03 Aircraft Connection Started
04:55:03 SimConnect: Event Received: SIMSTART, 0
04:55:03 SimConnect: Event Received: SIM, 1
04:55:03 Simconnect Version: 4.5.0.0
04:55:03 Aircraft FullName: PMDG 737-800NGXu
04:55:03 Synchronising Switches & Selectors .....
04:55:05 Synchronising Switches & Selectors Complete
and I have open LUA button and another window has open and I can see below error.
Lua Non Operational! See GIT Log For Errors!
I searched similar issue on this forum but I could not solved this issue.
could you help me about this issue?
thank you in advance
kevin
  • I have tried again but now there is yellow light on simconnect at status screen wit below log
    05:52:37 GoFlight Connection Starting.....
    05:52:37 SimConnect Connection Starting.....
    05:52:37 SimConnect Message Processing Started
    05:52:37 GoFlight Connection Started
    05:52:37 PMDG SDK option is OK in Prepar3D v5
    05:52:37 SimConnect: Event Received: Aircraft Type Changed
    05:52:37 SimConnect: Event Received: SIM, 1
    05:52:37 SimConnect: Event Received: PAUSE, 0
    05:52:37 SimConnect Connection Started
    05:52:37 Aircraft Connection Starting.....
    05:52:37 SimConnect Message Processing Finished
    05:52:38 SimConnect Connection Starting.....
    05:52:38 Creating Bespoke Vars
    05:52:38 Bespoke Vars Created
    05:52:38 Importing Bespoke Variables
    05:52:38 Bespoke Vars Assigned, Importing Bespoke Events
    05:52:38 Bespoke Events Temp Imported
    05:52:38 Aircraft Processor: SubscribeToSimObjectEvent Failed
    05:52:38 Bespoke Events Imported
    05:52:39 GoFlight Connection Started
    05:52:39 Aircraft Processor: SubscribeToSimObjectEvent Failed
    05:52:39 SimConnect Message Processing Started
    05:52:39 SimConnect Connection Started
    05:52:39 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    05:52:39 SimConnect: Event Received: SIM, 1
    05:52:39 SimConnect: Event Received: PAUSE, 0
    05:53:09 WinSock: Connection Failed: 전송 연결 연결된 구성원으로부터 응답이 없어 연결하지 못했거나, 호스트로부터 응답이 없어 연결이 끊어졌습니다에서 데이터를 읽을 수 없습니다.
    05:53:09 LUA Processor: Connect Exception - Unable To Connect!
    05:53:09 Aircraft Connection Started
    05:53:09 Simconnect Version: 4.5.0.0
    05:53:09 Aircraft FullName: PMDG 737-800NGXu SSW
    05:53:09 Synchronising Switches & Selectors .....
    05:53:09 SimConnect: Exception Received: UNRECOGNIZED_ID
    05:53:12 BespokeEventProcessor: Task Failed RunLUA(C:\Users\kwons\OneDrive\??\GoFlight Interface Tool\LUA\global.lua)
    05:53:12 Global LUA Event Running
    05:53:12 BespokeEventProcessor: Task Failed RunLUA(C:\Users\kwons\OneDrive\??\GoFlight Interface Tool\LUA\PMDG 737\global_aircraft.lua)
    05:53:12 Global Aircraft LUA Event Running
    05:53:12 Synchronising Switches & Selectors Complete
  • GIT uses TCP/IP to talk to the GoFlight Interface Module running in the Sim. So it's either one of the following:
    Your dll.xml does not have the entry for the module. You can find the file in C:\Users\your username\AppData\Roaming\Lockheed Martin\Prepar3D v5
    Your firewall is blocking communication between GIT and the module.
    The module is physically missing on disk.
    You can configure the DNS name or IP address to use in the LUA Config.txt file in Documents\GoFlight Interface Tool.
