No GIT plugin menu in X-plane 10 (v. Demo)
Hello,
(sorry for my English)
I bought GF Interface Tools today and I do not know what I'm doing wrong, because in X-Plane 10 (ver demo) in the Plugins menu, there is no GIT Pluin.
Please help.
  • Hello,
    During the installation you are prompted for the location of your X-Plane plugin directory. Re-install GIT and make sure the correct directory is chosen.
  • Thank you for your help, but ... Of course I did. With no effect.
    If you have multiple installations of X-Plane, the installer can install the GIT Plugin into the wrong directory. Simply locate the GIT Plugin in one of your X-Plane installations under Resources\Plugins and copy and paste the GIT Plugin folder to the correct X-Plane installation.
  • Thank you.
    Yes I know, I read about it. But I have only one installation of X-plane 10 (demo) on the desktop. I have a GIT in the plugins folder.
  • Make sure the GIT Plugin directory has directories and files in it and if so try running X-Plane as Administrator.
    If that doesn't work, there should be a file called GITLog.txt in the main X-Plane directory which I will need you to copy and paste on this thread.
  • GIT Plugin directory has directories and files in and run the program as administrator...
  • Can you post the log as previously requested.
  • 14-11-2018 00-52-56: GIT Plugin Starting ...
    14-11-2018 00-52-56: Message Pipe Running!
    14-11-2018 00-52-56: Client Connect ...
    14-11-2018 00-52-56: GIT Plugin Started!
    14-11-2018 00-52-57: Client Connected!
    14-11-2018 00-52-57: Connecting ...
    14-11-2018 00-52-58: Cleanup Running ...
    14-11-2018 00-52-58: Cleanup Write Data Refs ...
    14-11-2018 00-52-58: Write Data Refs Cleaned!
    14-11-2018 00-52-58: Cleanup Detective Vars ...
    14-11-2018 00-52-58: Detective Vars Cleaned!
    14-11-2018 00-52-58: Cleanup Commands ...
    14-11-2018 00-52-58: Commands Cleaned!
    14-11-2018 00-52-58: Cleanup Complete!
    14-11-2018 00-52-58: Cleanup Ended!
    14-11-2018 00-52-58: Connected!
    14-11-2018 00-55-24: GIT Plugin Stopping ...
    14-11-2018 00-55-24: Disconnecting ...
    14-11-2018 00-55-24: Cleanup Running ...
    14-11-2018 00-55-24: Cleanup Window ...
    14-11-2018 00-55-24: Window Cleaned!
    14-11-2018 00-55-24: Cleanup Data Pipe ...
    14-11-2018 00-55-24: Data Pipe Cleaned!
    14-11-2018 00-55-24: Cleanup Write Data Refs ...
    14-11-2018 00-55-24: Write Data Refs Cleaned!
    14-11-2018 00-55-24: Cleanup Detective Vars ...
    14-11-2018 00-55-24: Detective Vars Cleaned!
    14-11-2018 00-55-24: Cleanup Commands ...
    14-11-2018 00-55-24: Commands Cleaned!
    14-11-2018 00-55-24: Cleanup Complete!
    14-11-2018 00-55-24: Cleanup Ended!
    14-11-2018 00-55-24: Disconnected!
    14-11-2018 00-55-24: Client Connect ...
    14-11-2018 00-55-25: Cleanup Running ...
    14-11-2018 00-55-25: Cleanup Write Data Refs ...
    14-11-2018 00-55-25: Write Data Refs Cleaned!
    14-11-2018 00-55-25: Cleanup Detective Vars ...
    14-11-2018 00-55-25: Detective Vars Cleaned!
    14-11-2018 00-55-25: Cleanup Commands ...
    14-11-2018 00-55-25: Commands Cleaned!
    14-11-2018 00-55-25: Cleanup Complete!
    14-11-2018 00-55-25: Cleanup Ended!
    14-11-2018 00-55-25: Client Connected!
    14-11-2018 00-55-28: Message Pipe Stopped!
    14-11-2018 00-55-28: GIT Plugin Stopped!
  • That log indicates it is running OK. Is GIT not working? Have you tried using a profile from downloads with one of the default aircraft?
  • I think everything is OK.
    I thought GIT could be run directly in the plugins menu in XPlane.
    This is not possible for me.
    I do that:
    before launching X-Plane, I enable the GoFlight Interface Tool X-Plane from the desktop icon, and then I start X-Plane.
    I regret that I can not run GIT directly from the plugins menu in X-Plane.
