Question on Interface tool and Go Flight RP48Rotary
I Think Steve is gonna be sick of me . I talked my friend (well kinda of) getting the Interface tool , and on Team Speak since i'm some what getting a bit used to programming it we ran into a snag . On TeampSpeak had him bring up his interface tool cause he wanted to program a Wiper and the Auto brakes on the Rotary section of the RP48 but the button section seems to be fine . I have the wiper working on the PMDG 777 and the Auto Brake selector .I took pictures and sent him the same set as me , I guided him how to bring up the Device -Identify and select the same events that i have ----and mine work and his don't ,and we bought the Interface tool almost at the same time time his are not grayed out, he selects the same event as me for the wiper and Auto brakes and his do not work work . any idea's? LOUIS
09:25:51 GoFlight Connection Starting.....
09:25:51 SimConnect Connection Starting.....
09:25:51 Update Check Error Code: 0 - Exception: The request was aborted: Could not create SSL/TLS secure channel.
09:25:52 SimConnect Message Processing Started
09:25:52 GoFlight Connection Started
09:25:52 SimConnect Connection Started
09:25:52 Aircraft Connection Starting.....
09:25:52 PMDG SDK option is OK in FSX
09:25:52 SimConnect: Event Received: Aircraft Type Changed
09:25:52 SimConnect: Event Received: SIM, 1
09:25:52 SimConnect: Event Received: PAUSE, 0
09:25:52 SimConnect Message Processing Finished
09:25:52 GoFlight Connection Starting.....
09:25:53 SimConnect Connection Starting.....
09:25:53 Creating Bespoke Vars
09:25:53 Bespoke Vars Created
09:25:53 Importing Bespoke Variables
09:25:53 Bespoke Vars Assigned, Importing Bespoke Events
09:25:53 Bespoke Events Temp Imported
09:25:53 Bespoke Events Imported
09:25:54 SimConnect Message Processing Started
09:25:54 GoFlight Connection Started
09:25:54 SimConnect Connection Started
09:25:54 Aircraft Connection Starting.....
09:25:54 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
09:25:54 SimConnect: Event Received: SIM, 1
09:25:54 SimConnect: Event Received: PAUSE, 0
09:25:56 WinSock: Connected To localhost On Port 27015!
09:25:56 LUA Processor: Started!
09:25:56 Aircraft Connection Started
09:25:56 Simconnect Version: 10.0.61259.0
09:25:56 Aircraft FullName: PMDG 777-200LR
09:25:56 Synchronising Switches & Selectors .....
09:26:01 Global LUA Event Running
09:26:01 Global Aircraft LUA Event Running
09:26:01 Synchronising Switches & Selectors Complete
