ZiboMod 738
When I turn the Knob of the COURSE it is not continuous the numbers, so I say.
1,2,3,4,5,6 ...
it goes 1.2.4.7.9.14.19 ....
he does not go one by one he goes jumping multiple numbers.
I'm using profile (Zibo's B738-800 (MCP PRO, EFIS, GF166, LGTII) by David Williams) that has on the transfer page ....
Thank you
1,2,3,4,5,6 ...
Thank you
I'm not seeing the same issue that you're experiencing. Can you provide the b738 XML file and the GFMCPPRO XML file. I'll have a look and see if I can find anything that's different to mine.
Good night, sorry for the delay .... I found the MCP.PRO XML file I do not know where the Zibo XML file is anymore, is it inside the Zibo folder?
Thank you
Noticed a couple of changes that you don't have. I've attached my latest zip file for b738. I'd get rid of anything you currently have and re-import the new zip file.
I'll do the test, and I'll post the result here ...
did not work, same problem ....
