GoFlight SECM Rotary Switch
SECM - GoFlight rotary 5 position switch does not respond properly with the Carendo C210M Centurion airplane, but works correctly with the X-Plane Cessna 172SP and the Carendo CT182T - all have the same input events. Switch will respond properly from position 1 to 5 but not in reverse, starter is on all the time. The switch can be turned back using the mouse. Carendo claims it is not their problem.
If the Cessnas all use the same input events for this function switch there must be something different with the C210M airplane !!
Your thoughts on the issue.
Thanks Rene
  • You need to use detective and see what datarefs to use as it clearly is using a non-standard approach.
