GFIT Access to Detective Screen
Steve thanks for the tip on the Can 210 Centurion regarding the mag rotary switch.
Since I have had this program I have not been able to gain access to the prompts at the bottom of the page (Run Event in Background) (Update Editing) - I have tried almost everything to get the screen to fit the monitor so I can use the part of the software, I changed resolutions,etc. I can resize the screen with the right arrow to the left, and right top corner arrow at an angle but unable to bring the bottom up to access the prompts. If you wonder why I waited till now "its called embarrassed in not being able to figure this out on my own !!!).
Set Up:(2) i7-7700 PC, Brunner control feedback yoke and rudder, GoFlight modules and Volair cockpit. Displays (4) 40 inch TV's as monitors with normal aspect ratio, over scan turned off. works fine will all other software, your thoughts on what to do next!
Merry Christmas to you and yours
Rene
  • Hi Rene,
    Resize the window as you have been doing, then drag the window from the top to move it up (left click and hold on the first 1/2cm of the window).
