Problems with WinSock and X-Plane 11
Hello,
I have a problem using Goflight Interface Tool for X-plane 11.
Here is my log file.
16:16:00 GoFlight Connection Starting .....
16:16:00 X-Plane Connection Starting .....
16:16:00 Update Check Error Code: 0 - Exception: The request was aborted: Could not create SSL / TLS secure channel.
16:16:01 GoFlight Connection Started
16:16:02 X-Plane Connection Started
16:16:02 Aircraft Connection Starting .....
16:16:02 X-Plane: Event Received: Aircraft Loaded / Flight Loaded
16:16:20 LvarNamesUpdated!
16:16:20 Creating Bespoke Vars
16:16:20 Bespoke Vars Created
16:16:20 Importing Bespoke Variables
16:16:20 Bespoke Vars Assigned, Importing Bespoke Events
16:16:20 Bespoke Events Temp Imported
16:16:20 Bespoke Events Imported
16:16:20 Loading Aircraft Settings
16:16:20 GetXMLConfigData
16:16:20 GotXMLConfigData
16:16:20 Loading Power
16:16:20 Loading MCPPRO
16:16:20 Loading EFIS
16:16:20 Loading P8
16:16:20 Loading T8
16:16:20 Loading RP48
16:16:20 Loading MESM
16:16:20 Loading WP6
16:16:20 Loading LGT
16:16:20 Loading LGT II
16:16:20 Loading GF46
16:16:20 Loading GF45
16:16:20 Loading TQ6
16:16:20 Loading DIO
16:16:21 Loading GF166
16:16:21 Loading SECM
16:16:21 Loading Joysticks
16:16:21 Clearing Displays
16:16:21 Reset Data
16:16:21 Aircraft Settings Loaded
16:16:21 Calling Aircraft Changed
16:16:21 Aircraft Changed
16:16:22 XPlane: Event Received: Sim State 1
16:16:34 WinSock: Connection Failed: Unable to read transport connection data: A connection attempt failed because the connected party did not respond properly beyond a certain time or an established connection to failed because the login host did not respond.
16:16:34 LUA Processor: Connect Exception - The object reference is not defined to an instance of an object.
16:16:34 Aircraft Connection Started
16:16:34 Synchronizing Switches & Selectors .....
16:16:36 Synchronizing Switches & Selectors Complete
There seems to be a problem with WinSock.
Can you help me
Thank you and happy new year 2019
  • It looks like the plugin is not running. During installation of GIT it asks to verify the location to install the plugin. If you have multiple installations of X-Plane, the wrong version could be selected.
