MCP Pro and IFLY 747-800 (SP3) doesn`t work together
Hi anyone,
first many thanks for this program. I love it.
Now i have a Little Problem.
I`m using your Software with a MCP PRO and PMDG 737-800 since years properly
Yesterday i bought the IFLY 747-800 and tried to use the MCP PRO also.
But it doesn`t work together. First i installed the latest Version of your program and tried it again. Same result. It doesn`t work.
Crosscheck: PMDG 737-800WL it works fine.
Now my question: What i have to do, that i works with IFLY 747-800
I suppose that it works without a additional Setup or changes (plug and Play).
My System P3D v4.2 / MCPPRO /
Do you have an advice, what i can check that it works?
if the IFLY is startetd GIT recognize it and write Aircraft IFL747 / Generic on the Status page.
So i can`t switch between PMDG or IFLY
I have just released that iFly came out with a new Service Pack (SP3) a couple of weeks ago that provides the 800 series of the aircraft so I suspect the iFly SDK has changed so it will no longer work with GIT.
I will need a few days to update GIT to be compatible with SP3.
