SimConnect yellow with P3DV2.2 using 2.0.1131.0
I don't have legacy SimConnect installed on my PC, I'm using the managed SimConnect built into P3DV2.2 ... do I need to install legacy SimConnect?
Also, the only documentation I have is from 3/3/2013 ... is there anything more recent?
EDIT: I have donated as I think this project is well worth it.
I just downloaded the GFConfig tool so I have the latest version of that which is supposed to be compatible with P3Dv2.2.
Is P3D in sim mode i.e. you have an aircraft loaded and the virtual cockpit is visible. If not the tab will stay greyed out.
Here is my log, this was with the default King Air 350, thanks:
20:53:03 GoFlight Connection Starting.....
20:53:03 SimConnect Connection Starting.....
20:53:04 SimConnect Message Processing Started
20:53:04 GoFlight Connection Started
20:53:05 SimConnect Connection Started
20:53:05 Aircraft Connection Starting.....
20:53:06 Aircraft Connection Started
20:53:06 Simconnect Version: 2.0.0.0
20:53:06 Synchronising Switches & Selectors .....
20:53:06 Synchronising Switches & Selectors: Waiting for Simconnect .....
20:53:38 SimConnect: Event Received: Quit
20:53:38 SimConnect Message Processing Finished
20:53:39 SimConnect Connection Starting.....
20:53:40 SimConnect Message Processing Started
20:53:40 SimConnect Connection Started
20:53:40 Aircraft Connection Starting.....
20:53:41 Aircraft Connection Started
20:53:41 Simconnect Version: 2.0.0.0
20:56:52 SimConnect Message Processing Finished
20:56:52 GoFlight Connection Starting.....
20:56:52 SimConnect Connection Starting.....
20:56:53 GoFlight Connection Started
20:56:53 SimConnect Message Processing Started
20:56:54 SimConnect Connection Started
20:56:54 Aircraft Connection Starting.....
20:56:54 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
20:56:54 SimConnect: Event Received: SIM, 1
20:56:54 SimConnect: Event Received: PAUSE, 0
20:56:55 Aircraft Connection Started
20:56:55 Simconnect Version: 2.0.0.0
20:56:55 SimConnect: Exception Received: OUT_OF_BOUNDS
20:57:00 SimConnect Message Processing Finished
20:57:00 GoFlight Connection Starting.....
20:57:01 SimConnect Connection Starting.....
20:57:01 GoFlight Connection Started
20:57:02 Synchronising Switches & Selectors Complete
20:57:02 SimConnect Message Processing Started
20:57:02 SimConnect Connection Started
20:57:02 Aircraft Connection Starting.....
20:57:02 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
20:57:02 SimConnect: Event Received: SIM, 1
20:57:02 SimConnect: Event Received: PAUSE, 0
20:57:03 Aircraft Connection Started
20:57:03 Simconnect Version: 2.0.0.0
20:57:03 Synchronising Switches & Selectors .....
20:57:03 SimConnect: Exception Received: OUT_OF_BOUNDS
http://www.pollypot-software.org.uk/support/faq.html
