GF-46 blocking during flight (again)
The GF-46 was working for a while but today discovered during flight with ZIBO 3.33H and XP 11.31 again a blocking GF-46. Other modules continue to work. Restarting git or disconnecting the module didn’t help. I had disabled selective usb suspend in win10.
GIT is seeing the module as it states 1 in the module overview but turning knobs or push button, no reaction is seen in the status overview (green “indicators”)
Anyone a clue? Or share the settings?
Thanks!
Andre
  • To add....Have changed the USB settings in win10 registry which was posted in https://www.pollypotsoftware.org.uk/vanillaforums/discussion/comment/6609#Comment_6609
    So will be testing this the coming week. Will reply with the results...
  • After testing several options and settings on both win 10 and git it is still a nightmare with the GF46 and GIT. After couple minutes flying and cycling through the programmed functions the GF 46 blocks completely.
    All other panels keep on working.
    @steve: are there possibilities to trace down messages, errors etc. The log of GIT shows nothing wrong. Also the GF46 stays “connected” in the status tab but the GF46 doesn’t responds anymore
    Regards,
    andre
  • Hi Andre,
    Its a hardware issue. All you can do is reduce the risk by following the advice on the various threads about the subject.
    I will be raising this issue with GoFlight once John Greig is back there.
    Besst wishes
  • edited March 2019
    Did everything what was adviced in various threads but nothing helped so far. My GF45, RP48 and P8 are very stable so it got something to do with this particular panel. Maybe because it is a newer version panel (light grey instead of black panel) then the other ones.
    By the way, with GF46 disconnected completely, it still appears in the status tab. How can i solve that?
    Hopefully John can mean something to the issue.
    Kind regards,
    Andre
    Any update with John?
    Thanks!
  • Not sure if he has started there yet. Will email me to find out.
  • John's response. If you need his email address, PM me:
    Well, I have been fighting for years to have the 46 fixed as a lot of customers have problems with this module locking up. I did speak to the new owner about this and it is something that is going to be looked at but it is going to take some time before he has a chance. He is an electronics guy, unlike the previous owners. If you would like the test software I can send it to you. It's the test we use for production and send out to customers that are having problems with their hardware to determine if the hardware is bad. I suggest to customers that connecting the 46 directly into the computers USB and not thru a hub that works in some case but not all. If you have customers that are having problems you can send them to me and I will do what I can to replace or maybe exchange it for them for another module. Our support site is still not back up so you can send them this email address if you want and I will do what I can for them.
  • edited April 2019
    Hey Steve,
    Great and thanks for sending the response from John.
    I gladly want the test software to see what it is or sent back the module. I will sent you an email address for John to contact me :-)
    Sent you my email address via general inquiry form on your website.
    Regards,
    Andre
    In contact with John. No results till now. Will post any progression
    Test program received from John and tested the GF-46. Turns out that also with the test program the GF-46 won't function correctly. It hangs after 5 sec and turns into a dead block of steal...
    Kind regards,
    Andre
