New version ghosted
I can open log before I start FSX SE. I see Simconnect/Winsock connecting...then I start FSX SE/PMDG : GIT freezes.Mouse clicks do nothing.
SimConnect FSX is Green but Aircraft is showing Red
Thanks for any help.
  • Do you have a MESM connected?
  • Yes, I do have the MESM...I'll check to see if it is connected.
  • Not able to get to the sim for awhile:
    I remember that GoFlight had a problem with their MESM sometime back and had to initiate a fix.
  • Try it without the MESM as I have another customer where GIT locks up with the MESM, although I cannot recreate the problem yet.
  • MESM unconnected made no difference. The interface tabs are all ghosted/frozen.
  • I have just checked and its OK my end. If there are problems with Winsock it can take a while before it times out, so leave it for a minute at least. If still no good try renaming Documents\GoFlight Interface Tool and see if that helps. Also try it with a default aircraft and let me know if it still locks up.
  • Steve, the GIT works with default FSX . Used the 737-800. Restarted the sim, but still a no-go with PMDG. It does show SimCon connected...but Red light under Aircraft Mode: NGX pmdg.
    I may try reinstall of PMDG.
  • Same problem after reinstalling PMDG...reinstall new version GIT. I even reinstalled the older version of GIT but nothing.
    It does work in default FSX aircraft.
  • Check all the fixes under the FAQ entry: "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes or dashes)" here: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
  • Did the FAQ. Reinstalled GIT for FSX SE again. Same problems. Do I need a registration reset ? I haven't been asked for my existing KEY during all of these multiple downloads.
    Again, right before I open the FSX SE and load PMDGX, the lights are all green on the tabs of the GIT. When I load up a flight..GIT freezes. The Status is Grey and SimConn is Green and Aircraft (Mode NGX, etc) is Red.
  • If the old version of GIT is doing the same thing and that previously worked, then it indicates corrupt GIT settings file or something wrong in FSX. Perhaps a reinstall of the NGX would solve the problem.
  • Steve, I fixed the problem by entering PMDG 737 in the Aircraft Short Name window under the SIT settings. Whew. This was lengthy, but looking at the Log and the GIT Status, I couldn't see the 737 loaded. Thanks for your help.
    Doug
  • ...and I renamed the Document/GIT folder--maybe that was it. Will check in couple of days.
