GFDIO LEDs functionality
I search the answer without any avail, sorry if this has been answered before. I have two DIO boards, both work without the GIF tool. However, when using the tool , the second row of LED output does not work. I mean I program the out put but the LEDs remain unlit regardless if the action is called or even using the identify function of the tool. The second DIO only two pins (the second to last, from Left to right, top to bottom) behave the same way. Have you encounter this in the past? Is there a fix through the software?
