PMDG Engine Shutdown
I'm posting on behalf of someone who contacted me with an invalid email address so I could not reply:
"I am using the Goflight PMDG interface with the MCPPRO and PMDG737NGX. Everything works well until about 30 seconds after engine start, at which point I get a low oil pressure warning and the engines shut down. I am not using any other tool such as FSUIPC to program controllers and have tested this event in numerous way (with all other controllers disconnected and deprogrammed in FSX. I have done a lot of reading to try and sort this out but the forums often loose me before to long. HELP."
Hi Dallas,
I suspect its one of the following:
1) The aircraft needs maintenance due to a fault (use the FMS to sort this out).
2) You have assigned a fuel cut off event to switch/button (or some similar event).
