GF T8 inversed switches
On ZIBO Boeing 737 x_plane 11 to put the switch "on" need to put it down
On gf T8 to put it "on" with led light need to put it up
Have you a soluce to inverse ?
I would a similar action on the display and on the GF T8
Did you have some new about Goflight company when they start again ? Microsoft start a new software FS some new customers will arrive
Thanks for your help
    You can just swap the events around on the switch. So the event/command that is currently set for On, use it for off and vice versa.
    Goflight is already being run by the new owners. I suspect support will be added for FS2020 along with some new GoFlight products and a new website.
