Frustrated as GF MCP PRO Still Not Working
I have read the Forum about above, I can't find a solution to the problem. As you know the product was expensive.
There are no lights on the MCP when I start P3D but I get Three green lights on the GF interface, the third one flashes, it shows the correct aircraft, Config is set to Compatible Add on.
I am really at a loss as to why it is not working..I do not know how to contact Steve and I must admit I find the forum difficult to follow.
The last line in the GFinterface settings is: 13:03:04 Synchronising Switches & Selectors Complete
Any help and advice would be appreciated
  • konjan,
    See if this GoFlight file helps. Just place it in your GoFlight folder and run it. It will light up every LED showing if the unit is okay or not. You need firmware A25 or later. That can be seen briefly when you power up the MCP.
    Ray (Cheshire, England)
  • Is the MCP PRO Enabled in GIT for the aircraft selected?
  • Thanks Ray, I will try that. MCP Pro correct aircraft is selected.
  • I have run the Above MCPProChkA25.zip, lights came on etc and all appeared ok. I started P3d with PMDG 737-800 ran GoFlightinterface tool P3D 64bit, three green lights third (Aircraft) flashing but the GF MCP PRO still not working.
    What is Firmware A25? Any help once again would be appreciated.
    Regards Konrad
  • Whoops!! Just did a re-start on GoFlight interface and it is working!!! Thanks for the help, one happy pensioner!!
    Regards Konrad
