EFIS Zibo
Good day,
I have nearly fully programmed my EFIS , there are only two switches that I don't ghet to work.
SELECTOR_MODE and SELECTOR_RANGE here is an example of my SELECTOR_RANGE setting
POSITION1 laminar/B737/EFIS_contol/capt/map_range_up
POSITION2 laminar/B737/EFIS_contol/capt/map_range_up
POSITION3 laminar/B737/EFIS_contol/capt/map_range_up
POSITION4 laminar/B737/EFIS_contol/capt/map_range_up
POSITION5 laminar/B737/EFIS_contol/capt/map_range_up
POSITION6 laminar/B737/EFIS_contol/capt/map_range_up
POSITION7 laminar/B737/EFIS_contol/capt/map_range_up
The switch works but only in upwarts position, don't go down .
How must i programmed this switch to go left and right ?
Tx
Chris
Tx
Chris
Having problems with my EFIS ( Zibo ) can Range up but not down .
Also the Selector Mode is not working . Could you send me your working EFIS file for the ZIBO if possible.
Thank you in advancs.
Rgds
Dan
If that is not possible, then create a bespoke event for each position that reads the current dataref indicating the aircrafts current range position to determine how many map_range_up or map_range_down events to send. E.g. if the aircraft position is at position 1 and the bespoke event is called for position 2, then 2-1 = 1 and its greater than the aircraft's current position so send 1 map_range_up event.
