G166 Nav/Com problem
I have two units (original black ones) one I've configured using the default Com and the other the default Nav unit settings on xplane11 with a cessna182. I changed the Com settings to work with 833khz variables for display and inner frequency knob. Following initial setup they work fine with no issues when interface tool and xplane are restarted. However when I reboot the pc I have issues. Each 166 has the right config but the frequency display on the radio 166 are not displaying. The buttons and control knobs both work. The unit configured as Nav works fine. The display variables for the Com unit are set correctly. The only way to fix is to disconnect one unit, reload the settings for the connected unit, save, reconnect the second unit do the same and save. Works until PC rebooted and then Com display stops working again. Any help welcomed. Thanks
