GIT PMDG 777X Beta Bug Reporting Thread
This discussion has been closed.
Just a report on the Beta for the 777. Everything worked perfect..!!!!!!!
I thought you mentioned that the landing gear status lights did not work. In mine (GF-LGT the older one) they worked just fine, green when down, red when in transition and off when up and locked.
Just a few suggestions for guys with few buttons and switches. I know you are looking at some but here are a few more suggestions.
1. Cluster the Landing lights
2. Cluster the turn off lights
3. Cluster the CRT dim/brighten rotary so that 1 knob controls all screens brightness.
4. Cluster the back lighting on all the panels, left , right, and glare shield. 1 knob to control all.
5. Cluster the overhead lighting.
In fact the more you can cluster of events the better off we all are. Switches and knobs are a premium and we only have a few of them. But only do what you can, it is just and idea or suggestion for you.
1 question, I found the data for the master caution light to drive the WP6 panel but I could not find the event to program the WP6 button to reset it. Do you know where it is or what it is called?
I am not sure if all those can be done, but if they could that would be great.
Again I can not say thank you enough for what you have done in getting this equipment to work with PMDG and others. I have about $2000.00USD in go-flight equipment and without your program I would be using the mouse to fly the PMDG aircraft. Thank you!!!
I would like to tell you that the new beta GIT works perfectly with the PMDG B777X for me.
Since november last year I use the MCP, LGTII, RP48, 166, Yoke system and TQ6. All worked very well with the PMDG B737NGX. Since the arrival of the PMDG B777X I was hoping you would be able to get the software running for that plane as well. And so, a few days ago I discovered there was a new Interface Tool.
It took me two hours to get it running with the B777 and it looks as though I have no issues with it. Unbelievable. I just made a donation for your great work.
Thank you very much indeed.
Peter
Thank you for your kind words and generous donation Peter, its very much appreciated. A new version will be out shortly with updated cluster events.
Hello Steve,
First, the GFIT Beta Ver. 2.1.2.0 works well and I've encountered only 2 relatively minor issues.
1) Cargo doors (all) - Thus far, I'm baffled. Can not get a LED to light correctly when the doors are either open or closed. (Not a problem with cabin doors). Any suggestions?
2) PMDG 777-300 - Opening and/or closing DOOR 5L or 5R can not be assigned. It would appear "EVT_DOOR_5L" and "EVT_DOOR_5R" are missing under the Custom Shortcut Events listed in the PMDG 777 SDK header file.The GFIT Beta does have a "DATA_DOOR_5L" and "DATA_DOOR_5R" that will light a LED (if that door is opened using the FMC CDU).
Claude
"OVERWING"? Well I suppose I might well have stumbled on that over time if I tried. ;-).
Thanks! And we'll patiently await the next release.
All Light are green and the right LED flashes green. But no function with my MCPPRO.
Thanks for help
Klaus
