MCPPRO for PMDG 737 NGXu (NGX also) with dashes. Stop worked after the install NGXu
Hi Rob, I need you help here
I never had issues with MPCPRO and GIT in the last 5 years.
But now, I am getting the dashes after I installed NGXu and NGX is also getting dashes also.
My config/setup : GIT 3.7.0.1 and GF drives 2.28 , .NET last version, W10 and P3d V4.5.
For the others aircrafts, the MCPPRO works like a charm (default mode), but for NGXu and NGX in compatible mode I have the 3 green lights and dash in the displays.
I already reinstall GIT and GF several times and trying install in C: root also.. I also read the FAQ as your recommedation and reinstall NGXu.
See the log below :
23:08:31 GoFlight Connection Starting.....
23:08:31 SimConnect Connection Starting.....
23:08:32 SimConnect Message Processing Started
23:08:32 GoFlight Connection Started
23:08:32 SimConnect Connection Started
23:08:32 Aircraft Connection Starting.....
23:08:32 PMDG SDK option is OK in Prepar3D v4
23:08:32 SimConnect: Event Received: Aircraft Type Changed
23:08:32 SimConnect: Event Received: SIM, 1
23:08:32 SimConnect: Event Received: PAUSE, 0
23:08:32 GoFlight Connection Starting.....
23:08:32 SimConnect Message Processing Finished
23:08:33 SimConnect Connection Starting.....
23:08:33 Creating Bespoke Vars
23:08:33 Bespoke Vars Created
23:08:33 Importing Bespoke Variables
23:08:33 Bespoke Vars Assigned, Importing Bespoke Events
23:08:33 Bespoke Events Temp Imported
23:08:33 Bespoke Events Imported
23:08:34 SimConnect Message Processing Started
23:08:34 GoFlight Connection Started
23:08:35 SimConnect Connection Started
23:08:35 Aircraft Connection Starting.....
23:08:35 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
23:08:35 SimConnect: Event Received: SIM, 1
23:08:35 SimConnect: Event Received: PAUSE, 0
23:08:38 WinSock: Connected To localhost On Port 27015!
23:08:38 LUA Processor: Started!
23:08:38 Aircraft Connection Started
23:08:38 Simconnect Version: 4.3.0.0
23:08:38 Aircraft FullName: PMDG 737-800NGXu SSW
23:08:38 Synchronising Switches & Selectors .....
23:08:53 Synchronising Switches & Selectors Complete
See the log below :
I followed the FAQ but no success. I changed manually the value in the tab MCPPRO to LNAV (was blank) then the 7displays shows up.
