After Systemcrash the MCP doesn't work
Hello,
i use Goflight MCPPRO with p3d pmdg 737. After a Systemcrash the MCPPro doesn't work. I have change the usb-slots without a positive result and i set windows to last rescue point. I have uninstall and reinstall the GIT but its no positive result. Is there a way to delete all drivers and registry keys? I think Windows had a wrong MCP-driver and so the GIT can't start the MCP correctly...
i hope you can help
tobi...
i hope you can help
tobi...
21:11:10 GoFlight Connection Starting.....
21:11:10 SimConnect Connection Starting.....
21:11:11 SimConnect Message Processing Started
21:11:11 GoFlight Connection Started
21:11:11 SimConnect Connection Started
21:11:11 Aircraft Connection Starting.....
21:11:11 PMDG SDK option is OK in Prepar3D v4
21:11:11 SimConnect: Event Received: Aircraft Type Changed
21:11:11 SimConnect: Event Received: SIM, 1
21:11:11 SimConnect: Event Received: PAUSE, 0
21:11:11 GoFlight Connection Starting.....
21:11:11 SimConnect Message Processing Finished
21:11:12 SimConnect Connection Starting.....
21:11:12 Creating Bespoke Vars
21:11:12 Bespoke Vars Created
21:11:12 Importing Bespoke Variables
21:11:12 Bespoke Vars Assigned, Importing Bespoke Events
21:11:12 Bespoke Events Temp Imported
21:11:12 Bespoke Events Imported
21:11:13 GoFlight Connection Started
21:11:13 SimConnect Message Processing Started
21:11:13 SimConnect Connection Started
21:11:13 Aircraft Connection Starting.....
21:11:13 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
21:11:13 SimConnect: Event Received: SIM, 1
21:11:13 SimConnect: Event Received: PAUSE, 0
21:11:15 WinSock: Connected To localhost On Port 27015!
21:11:15 LUA Processor: Started!
21:11:15 Aircraft Connection Started
21:11:15 Simconnect Version: 4.3.0.0
21:11:15 Aircraft FullName: PMDG 737-800NGXu SSW
21:11:15 Synchronising Switches & Selectors .....
21:11:30 Synchronising Switches & Selectors Complete
