Toliss A321 Configs
I started working with the detective on the 321 to get things like switches and such working but Im having an issue. IE: I found all the detected taxi light on events, set them up, however when I test them the switch animation works, but the taxi lights "in sim" flicker on then off. When I monitor it seems something is forcing the data refs back to 0. Has anyone seen this before?
  • There may be several data refs that need to change in sequence. Also try using events instead.
    yes , i have similar issues with Toliss A319 and am looking for a soloution as well
  • Hello,
    I am also busy with the taxilights but also run into a problem. According to the dataref tool there is an action which I don't find back into the detective.
    Did somebody already sorted this out.
    Regards,
    Cor
