so here's my issue - doesn't come on with Value of 1, but with some experimentation, does come on with a value of 2. The problem is, the Nav button actually cycles Nav and Nav GPSS modes. I have this part working and mimics the Nav button in the sim. However, with repeat Nav button presses, it will cycle the Nav light, even though the autopilot (in sim) remains in Nav mode- alternating Nav and Nav GPSS- hope that makes sense. There may not be an easy way to fix this, but thought I would put out there.
Appreciate your help!
Bentley
Start bespoke events run automatically when the plane loads, so the bespoke variable will always be up to date. Make sure you add a Sleep(500) in the bespoke event otherwise your CPU usage will go to 100%
You can do the same thing in Lua if you prefer.
Bentley
