New setup P3D4 with MCP and GF-ICCS not working
I just buy Goflight products and when i Start Prepar3D and i dont receive a Simulator Security Warning about loading "Goflight Interface Module.dll
I have place GFDEV64.DLL into module file as suggest by Peter Downson.
I have the latest GOFLIGHT version GIT 3.7.0.1 for MCP and the Goflight version 2.28.0.2 for the radios GF-ICCS.
I start P3D4 and i dont have any connection to MCP PRO and others Goflight modules GF-ICCS dont light up.
No warning indication about loading "Goflight Interface Module.dll.
I have also follow instructions from Pollypot for :
Using notepad, open the dll.xml file and locate the following line: False
Immediately under this line, copy and paste the following, changing the directory included within to the directory where you installed this software:
GoFlight Module Interface
False
C:\Program Files (x86)\GoFlight\GoFlight Interface Module.dll
What is the step to get thoses things works properly from the box. Is there some steps to do to start before starting P3D4.
I am lost and i am asking if anyone can help me to get thoses modules working.
False
I Start the flightsim P3D V4.5 , then after loading my aircraft , i Start GIT P3DV4 64 BITS , after everything goes GREEN then i Start GFDevP3dV4.exe. from the Goflight file. So now i can see all of my Goflight modules such like COMM 1 and 2 , NAV 1 and 2 , ADF , and transponder . So now what i did its creating a shortcut on my desk to access each time to GFDevP3dV4.exe to run my Goflight modules.
Comments:
Very Strange how it works . I suggest maybe GOFLIGHT or Pollypot to produce a step by step guide to get it works on how to start the Goflight driver because i found it myself. I am very satisfied for the Goflight interface tool P3dV4 - 64 bits. The problem is with the driver Goflight config 2.2x.x wich is a major tool to run others Goflight modules such GF-166 radios and NAV and GF-46 . Nothing on the Goflight web site to explain that we need to go Inside the files and look for GFDevP3DV4.exe if you use P3D or GFDevFSX.exe for FSX.
I spend more than a thousands dollars into Goflight products and spend many hours to get it works.
Best regards
