21st November: A new version of the GoFlight Interface Tool for FS2020 is now available.
XP11.41 Zibo mod help required
Gentlemen, until recently my MCP was working correctly. Currently it works with the default XP but not the Zibo anymore. Please assist with the datarefs file or instruction as to get it working again.
I will gladly answer question to help with the troubleshooting effort
Can you post your XML file from ...\Documents\GoFlight Interface Tool directory and I'll have a look/
I can see your events and variables, although I don't use lua scripts. I don't see the xml for the MCP device. Do you have a backup directory? The backup should have a file called SettingsXPlane.xml.bak. Have a look in there to see if the MCP is define in there.
If it is you can copy it back into the ...\Documents\GoFlight Interface Tool directory, getting rid of the .bak extension and replace the file with the same name.
Hope that helps.
Some clarity on this would be appreciated as it does not seem to be on the user side.
1. an admission that current software has problems and its being addresed. This will save me further scratching in the dark looking for eroneous ansswers.
2. if the software is not the issue, positive support with my issues and which have been highlighted and submitted, see above.
im getting to lose faith.
respectfully
I ment comparing the drefs file in the zibo acft folder with what is setup in GIT.
I have no mcp but other panels like the GF45 which stop working after the latest update of windows 10...
I am not far away from switching of from goflight modules. I find it hard to understand that paying a lot of money for panels and goflightinc is rigid in building support for XP. While this is easy to do with plugins.
log file attached
If it still doesn't work, disable your firewall as this may be blocking communication. It will be working when this message stops appearing "GIP: Pipe Connect Failed!"
sincere grateful thanks for your support. my issue was NOT with your software but with my windows 10 system.in short it had been corrupted. I am now successfully using the latest software after a fresh install of my operating system. not of that would have been possible without your support, so a huge thank you. I feel it is only right that you should know your efforts were not wasted.
kindly
john
