GF-LGT II in P3D v5
Hello Steve and all:
This is not a request to "fix anything" but rather, a request for some advice.
While all my GF modules programmed or activated via the GFIT are working great in P3D v5, the landing gear lever of the GF-LGT II does not do anything.
I have to imagine, that it is because I have not installed the GF software in P3D v5, as I have not been able to find any updates to their latest (2.28.0.2).
Is that the cause?
Thank you for any advice or guidance
Roberto
  • Hi Roberto,
    Once I read your post, I knew what I have gone and done. I'll get a fix out today.
  • I'm wrong, the code is fine. What aircraft are you using and are there events assigned to the gear lever?
  • Hello Steve!
    There are no event assignments for the LGT II.
    In v4.5, the lever will activate the gear in any aircraft, even when the GFIT is not turned on.
    In v5, other than the default aircraft, I have managed to install the Majestic Q400 and A2A's Bonanza and Comanche.
    The lever will not activate the gear in any of these aircraft, nor the default.
    Regards.
    Roberto
  • OK, what was doing the gear changes was your GoFlight drivers and they don't support P3D v5 as yet. If you load up an aircraft and then click the Default FS button on the LGT tab and then enable the LGT in GIT, it should work. Remember you will need to do this for each aircraft where the gear is not working.
  • Fantastic!
    It worked!
    Thank you again.
    Please take good care.
    Roberto
