ELEV TRIM AILE TRIM RUDDER TRIM doesn't works
i have bought a goflight interface tool, but the rudder tri, elev trim ancd aileron trim doesn't works, the other switch works perfectly.
the software i have installed, i think work, because, all 3 green dot is brightless.
i have GF-LGT II
Can someone help me?
Andrea
i have GF-LGT II
Andrea
If its a PMDG aircraft, it should be configured automatically, otherwise you need to click on the Default FS button on the LGT tab to configure it with defaults that work with most aircraft.
i used Flight Factor A320, and i had click the default FS button, but doesn't works
There are some good videos at the end of the beginners guide to get you up to speed: https://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/46-beginners-start-here/151-beginners-guide.html
