P3Dv5 GIT problems with SIMCONNECT_MENU_x
I have both P3Dv4.5 and P3Dv5 set up on my system, both with corresponding FSUIPC versions, and GIT.
I have set up a config where I use hardware buttons/interface to call up add-on interfaces such as GSX, ActiveSky, ProATC, SODE, ControlJ (by sending keystrokes) and buttons corresponding to the numerical menu selections, 0-9 by using the SIMCONNECT_MENU_x (where x is 0 thru to 9).
This works well in my P3Dv4.5 setup, but it seems that the SIMCONNECT_MENU_x events aren't working when used in P3Dv5.
I have no idea if this is an issue with GIT, GIT<->FSUIPC6, FSUIPC6 or P3Dv5.
I will need to do some testing at my end and come back to you.
