GIT Freezes
Hi Steve
Why do things work one day fine and then fall over the next
The application halted this morning as it did a month or so ago and I followed the instructions again you sent then.
Upon Uninstall & reinstall ( into the goflight directory ) , I ran the tool and it freezes . I have attached the log page , the user file and the empty User/Appdata/roaming folder .
Thanks in advance.
Adrian
  • An XML file is corrupt. Try deleting C:\Users\\AppData\Local\PollyPot_Software. If that doesn't work, restore from backup Documents\GoFlight Interface Tool. If you don't have a backup, you can try restoring the files from Documents\GoFlight Interface Tool\Backup; renaming the files as necessary. If all that fails, delete Documents\GoFlight Interface Tool and prepare to configure everything again.
