V/S wheel reversed on GF-MCP Adanced Autopilot - PMDG737
I am using the GF-MCP with the PMDG737, I have not programmed anything in the GIT as apparently it is preloaded with the PMDG config already. Everything works perfectly except the V/S wheel operates the wrong way round i.e. when I roll the wheel up I get a positive climb instead of negative. I can also see it is spinning in the opposite direction to that in the virtual cockpit, which confirms it is wrong. I can't seem to find how to correct it in the GIT either. Has anyone else had this problem and if so how can I correct it?
