GoFlight RMK-166
Hello Guys,
I need help configuring couple of RCPs that I recently purchased that have goflight RMK-166 which is an older card, I hope that someone have the diver or any documentations or possibly have a way to get them to work and interface with either PMDG or PSX using P3D V4.5 simulator.
Thanks,
Sam
Thanks,
Sam
I have not heard of the RMK-166 devices. Are they like the GF-166? I would recommend loading up the Beech Baron 58, enabling the GF166 by picking Device 0 in the combo box and selecting ENABLE. The hit the COM button on the GF166 tab and then turn the rotary to see if it springs to life.
Ray (Cheshire, England)
I think the difference between RMK166 and GF166 is that the RMK 166 comes as a kit which has the interface board, wiring kit and displays separate in order to convert an actual aircraft radio panel which uses ARINC 429 into USB PC panel by removing the original electronics and replace them with RMK166 components, which is a great idea, gives you the option to use original parts without the need to use ARINC429 interface cards which are costly and not guarantee to work.
