IAS / MACH window stays blank and EFIS problems
Having the following problems with the MCPpro and EFIS , ZIBO 738-800 Mod , running WIN10. ,
Everything worked fine during more than a year but since a couple of days the IAS/MACH window on the MCPpro stays blank ( or 0.00 ) .
but I still can change the IAS speed when turning the MCPpro rotary ( IAS window MCPpro staying blank ). All the other MCPpro buttons and rotaries working OK.
On the EFIS the range is only increasing when I toggle the GF-EFIS rotary between 320 and 640 and decreasing when toggling between 10 and 20 range. The MAP selector is not working at all. All the rest of buttons and rotaries are working ok .
When I run X-plane 11 using the same GIT aircraft configs on WIN7 I have no problems at all.
During the last couple of days I received 4 WIN10 updates....
I am using following GF modules 4 X GF166 , 1 X GF46 , 1 X GF48 , GF TQ6 , GF MCPpro , GF MSM , GF EFIS , GF LGTII , connected via 3 powered Hubs into USB2.0 . GIT vers. is 2.0.16.3 .
Thank you in advance
Dan.
  • Have you updated the Zibo as this would cause these types of problems?
  • Zibo was updated to B737-800X_3_40 RC2 full on 19/03/20 and all was OK until last week.
    Will download and install the latest Zibo update B737-800X_3_42 full and keep you informed .
    Rgds.
  • Steve,
    Installed latest Zibo Mod b737-800X_3_42 but still same problem.
    Also tried with an older Zibo Mod 800X_3_32 , same results.
    On this computer I only have X-Plane11 installed + necessary programs , nothing else.
    The only change before problem showed up were 3 updates for Win10 version 1909.
    Best Rgds
    Dan.
  • Steve,
    Re-entered the "Input Event " for the " Rotary IAS " Input and the " Light/Disp- data " for the "Display_IAS " Input
    and the MCPpro now working OK .
    EFIS : Now I can swich the MAP selector between MAP and PLN . Can change the Range but still not perfect .
    Trying to find out why.
    Rgds
  • I would try deleting PMDG.xml in Documents\GoFlight Interface Tool. This will force GIT to reconfigure everything back to defaults, but you will need to re-enable your hardware in GIT.
