P8 ... anyone have a sample of how to get the Button to toggle a state?
I've got my Bespoke events setup and working (Detector test) setup an ON state and an OFF state. However I'm having a hard time trying to figure out how to get the P8 button to toggle the states.
It seems On = ButtonDown while Off = ButtonUp ... so I can't set the Bespoke event to either state otherwise the button just goes ON the OFF immediately when I press and release the button.
The button I testing with is the CS 777 APU Gen button, press the button in and it goes ON, press the button again and it goes OFF. Pretty simple ... but I sure can't seem to get the toggle state mapped to my P8 button. I can use two separate buttons to accomplish On/Off, but that's not what I really want to do.
Anything other than a Button Action = NOTHING doesn't work at all.
Any hints or samples?
I would like to see how you did that but link is broken.
Hi Terry,
Here ya go:
<Event Name="BE_APU_GEN_TOGGLE" ID="5" Backgnd="False">
<Task ID="0" Type="If" Var="O03_002_BUT" Operator="EQUALS" Value="1" />
<Task ID="9" Type="Goto" LabelID="8" />
<Task ID="13" Type="If" Var="O03_002_BUT" Operator="EQUALS" Value="0" />
<Task ID="14" Type="Goto" LabelID="10" />
<Task ID="8" Type="Label" Name="OFF" />
<Task ID="1" Type="Set" Var="O03_002_BUT" Data="0" />
<Task ID="12" Type="Goto" LabelID="11" />
<Task ID="10" Type="Label" Name="ON" />
<Task ID="5" Type="Set" Var="O03_002_BUT" Data="1" />
<Task ID="11" Type="Label" Name="EXIT" />
</Event>
Thank you!
