Very Nasty Looking Error GTiF Imeediately crashes with Application Halted Error P3DV5 HF2
The invocation of the constructor on type ‘A.WM’ that matches the specified binding contraints threw an exception.
running GoFlightInterfaceToolP3Dv464Bit_Setup_3_8_0_0
GFiT crashes immediately with above the error message only the start of the error see attached file for full error message.
Tried clean install - same error
Tried moving documents GTiF folder in case it was something corrupt in config file but got same error
Hppens both with or without simulator
Yikes
Musky2015
  • edited July 2020
    Try deleting C:\Users\your username\AppData\Local\PollyPot_Software
  • Many thanks, that solved main CTD but noticed settings.xml was completely corrupted, had to restore it from a backup.
    All seem well now
    Mark
    Musky2015
