How to program a Rotary Encoder in GF-DIO.
I have been trying to use a Gray Rotary Encoder (CT288) with the GF-DIO in order to model the N1 and Speed Reference controls and selectors in the NGX. I have connected the Pin A of the encoder to on of the outer input pins in the board, Pin B to the opposite outer pin and Pin C or middle pin of the encoder to the ground (middle) connector of the board, and I made sure I don't have overlapping connection with other pins I have programmed the the Interface tool with a rotate/rotate-reverse command. When I rotate left or right I get a signal and the expected movement occurs on the first dent, on the second and third dents nothing happens and in the fourth the opposite command happens, negating the original movement. I though that this might have been due to dent noise and added some capacitors to the connection, to no avail. How can I connect and program a rotary encoder in the GF-DIO? I assume it can be done as goflight uses rotary encoder for their poducts
Esteban
  • edited November -1
    Hi Esteban,
    As far as I know, the DIO only supports Goflights own rotaries which have 6 or 12 wire connectors. You would need to check with Goflight themselves to determine if other rotaries can be made to work with the DIO hardware.
    Thanks Steve, I'll I ask the question in goflights forums.
    However, if I use a 12 pin rotary switch, how do you then model a contant rotation like the rotaries in the EFIS or MCPRO? I don't think this to be possible, right?
    Hi Esteban,
    For EFIS style slectors, the additional selectors at the end would be ignored. There is a special Event action called Selector which increments and decrements a variable so its all automatic.
    I'm not sure rotaries like those on the MCP are supported at all.
