MSFS: Is it normal that I have to reconfigure GIT at every launch of the simulator
I don't know if it is supposed to be like that, but every time I start a new session of MSFS (with GIT 4.2.0.0 started), my Goflight modules are blank and dead. Pressing a button on the GF-166s or the MCP-PRO does not wake them up. GIT status is displaying all green.
I must reconfigure them in GIT every time.
MCP-PRO > Device 0 > enabled > FS Default
GF-166 > Device 0 > enabled > COM
GF-166 > Device 1 > enabled > NAV
GF-166 > Device 2 > enabled > NAV
Only then do they come alive. Shouldn't GIT remember my configurations ?
I understand that GIT for MSFS is still work in progress and I appreciate your efforts, I just wish that there is a way to avoid having to do this every time I start MSFS. Any suggestions ?
  • Oh brother. If this is that under developed, I'll wait before I try and figure out how to set my stuff up in this tool. I don't even know how to download the updated version. It would be nice if the tool updated itself.
  • NBouc,
    No it shouldn't be doing that and I'm not seeing that behaviour on my PC. Can you try renaming Documents\GoFlight Interface Tool so GIT starts with new config files and try re-configuring again and see if it sticks. Also make sure GIT is quitting as that is when the settings can saved.
  • GS FS2020 is available in your account downloads, along with all the other versions. See the last entry in this article for more info: https://www.pollypotsoftware.org.uk/support/need-assistance.html
  • Thank you Steve for your reply, you told me exactly what I needed to know. I followed your advice and also applied the guide lines provided in your “FS2020 Feature Status and Usage” post. It looks like my problem is now solved.
    I think that my initial mistake was to believe that once GIT was configured for a default aircraft, it should work for any other default aircraft.
    I want to express my gratitude to you for providing us with a version of GIT for FS2020 so quickly, and that works quite well I might say. Being able to use my Goflight modules in FS2020 makes my flights so much more enjoyable.
    Best wishes,
    Normand.
    I have the same problem every time I start GIT and the SIM I need to reconfigure all of my 11 modules.
