WP6 LT Action Field with two conditions
Hello, I'm looking for a possibility to assign WP6 Module Light Action field to a condition like between two values - e.g. to illuminate Autobrake LT if in RTO or in AB POS 1 or more = LT OFF in OFF and Disarm - meaning for PMDG B777 Light is OFF for Light Values 1 and 2.
Thanks for help in advance, best regards
Ralf
  • edited September 2020
    You can use ON GREATER THAN with a Custom Value of 0 so it lights up when enabled and when at 0 its off.
    PS: Sorry mis read it, you want it the other way round, use OFF GREATER THAN
  • LT should be on at less than 1 and at greater than 2 (two conditions)
    Ralf
    You would need to write a bespoke event or a lua script to do that and put the result (0 or 1 for off and on) in a bespoke variable and assign the bespoke variable to your button/light.
  • ok thank you, will tryout with bespoke event - I have no idea regarding lua scripting...
    Ralf
