WP-6 PANEL ASSIGNEMENTS
is there anywhere a possibility to assign different WP-6 or T8/P8 panels to a fixed number in GFIT, I have several panels and especially for the WP-6 there are often mixed in new sequence, using W10 with P3dv4.
Ralf
Ralf
Sadly not. The GoFlight SDK determines the devices device number and I have no control over that. You can manually edit the settings.xml file to swap the device id's around when it happens.
I will add it to the dev plan to try and find a work around or easier fix.
Best regards Ralf
