TQ6-ADV
Shouldn't the TQ6-ADV throttle tab be clickable? It's recognized in the goflight software but unclickable in yours. I use latest versions for all. And an additional question, what would be the right configuration in the goflight software to make it work with the PMDG 737NGX? Now it seems not to go down all the way (in fsx that is) but maybe I do something wrong. Help appreciated.
Regards...Marc
Regards...Marc
Hi Marc,
Can you double check you have the latest GoFlight drivers. They only added support in the SDK for TQ6 detection in the most recent versions.
Its certainly working for me OK and I have two TQ6's (one basic and one advanced).
Send me a copy of your log and status screen if everything is up to date and I'll investigate further.
For the NGX the buttons are configured automatcially. Your screen should be set as per the attachment.
Steve,
I just downloaded the 2.22 goflight driver and installed it cause I thaught I had wrong version. But in the about section it still says version 2.21 build 10;0couyld there be something wrong? I'll send the log and status in a while.
Regards...Marc
Hi Marc,
So does mine, so no worries. If the TQ6 tab is still not enabled please attach screen dumps of the status screen and copy and paste your log.
Here they are attached.
Regards...Marc
Hi Marc,
The image you provided shows the TQ6 tab enabled - I'm a little confused now; are you saying that when you click on it the TQ6 screen doesn't appear?
Sry Steve,
No it shows up but I cannot click on anything like buttons aand so but maybe that's normal? If so I'm sorry.
Hi Marc,
When using the Interface Tool with the NGX, The TQ6 is pre-configured. All you can change is the device to use and whether you have the throttle handles installed into an older TQ6.
Apologies for the misunderstanding.
