DHC6 .xml files for GIT
Here are my Twin Otter files (Aerosoft):
Includes MCP-Pro ... got most of the switches/knobs ... forgot to do boost pumps. Included files here:
Aerosoft_DHC6.xml
Aerosoft_DHC6_GFMCPPRO.xml
BespokeEvents.xml (don't NOT overwrite your existing BespokeEvents.xml, merge the file)
BespokeVariables.xml (stubs only - again, merge the file)
Settings.xml (don't NOT overwrite your existing Settings.xml, merge the file)
Set to "Aerosoft_DHC6" so any variant that starts with this should work.
Feel free to do whatever you like with these Steve.
More aircraft to come later.
Hi Rob,
There is an Export function in detective for exporting Bespoke Events and then people can use the Import function in Detective to load them in easily instead of manually merging the files.
Hi Rob,
BespokeVariables.xml simply stores the names of bespoke variables if you have renamed them.
