Overhead Panel Brightness activation with just one button click of a module
Hello,
i would like to use the GF 166 module to activate the Overhead Panel Brightness of the PMDG 737 NGX with only just one button click.
Within the PMDG you have to click the right mouse button several times to activate the Panel Brightness.
Is there a way to Switch on/off Panel Brightness with just one module button ?
Assigning a normal right click to the button and the correct Event doesnt work for me :(
Thx !
Andi
  • edited January 2015
    Hi Andi,
    Generally the NGX light rotaries go from 0 to 150 brightness. So just send the event with a action of CUSTOM and the brightness level you want, say 100.
    EDIT - to do the on/off you would need a switch or two buttons so different values can be sent with ON or OFF. Alternatively use HOLD for the button to turn it OFF (send 0 as the CUSTOM value).
