GREEN LIGHTS NO TABS....and SIMCONNECT OPENING ADDITIONAL PORTS after simconnect.xml executed
WIN 10 i7,16GB, GF2.28.02, GIT FSX SE, FSUIPC 4.975, .NET 4.8+, all win updates
GIT all green lights, synchronization switches complete, but still no tabs enabled
yes aircraft loaded, running, in virtual cockpit, all firewalls disabled eset, windows defender etc, all other adhoc remedies attempted from all forums
They become enabled adhoc, every couple of computer reboots, and only after about 5mins in sim mode.Even went holistic approach and checked windows10 file and print sharing general settings as related to simconnect from other websites
Simconnect is only running latest version, no difference wether legacy versions installed or not.
4.8+, (SIDENOTE ...GIT config file refers to 4.6.2, and this entry cannot be edited and saved due to author admin window when attempt to save)
Simconnect debug windows shows the simconnect.xml file ports of global IPv4, and local IPv4 and local IPv6 all open, and pipe connection open also.
***** Then Simconnect opens an additional local IPv4, and additional IPv6 to random port numbers eg 57092/57093
If you edit simconnect.xml file to use these ports 57092/57093, again it opens and additional two random ports eg 49820 49821, so you cannot ever list the recurring extra two ports in your editable simconnect.xml file
These two extra ports are opened AFTER simconnect.xml file has executed to use defined port settings in the file.
This is why removed legacy versions in case multiple Simconnects were running.
Still all green on GIT, GIT says all connected, and synchronised complete, but STILL NO tabs enabled ....NEED HELP !!!!
